Stalls in rain?
Old Apr 30, 2008 | 01:24 AM
MU71L4710N's Avatar
MU71L4710N
Default RE: Stalls in rain?
ORIGINAL: jim135666
and what are symptoms of hydrolocking?
your car doesnt move
in december i hit a huge puddle with my cai on (i switched to just a k+n drop in with the boot off right after this happened). stalled out my car, it wouldnt stay running unless i had the gas pedal pressed, etc... i cleaned and dried the maf out the next day, threw the stock intake back on with a k+n, and it fired right up just fine. even a little bit of water hitting the filter can work its way up and throw your maf readings off.
i would take out your maf, clean it, find a way to block the water, and see how it goes.
Old Apr 30, 2008 | 03:06 AM
Ehmark's Avatar
Ehmark
The only symptom of hydrolocking is the engine not turning over. At the boat rental I work at whenever a jetski fills with water we change the air filter pull out the sparkplugs change the oil and then turn it over a few times with no plugs in it so the remaining water shoots out. Works everytime saved my *** once. (I put too much seafoam.) Spray some electronic parts cleaner on the metal contacts for the spark plug wires they get dirty.
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
jerrytubes
Oct 23, 2015 12:11 PM
Dathan
Oct 5, 2015 05:52 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
