COnvertable top Adjustment
Old Apr 22, 2005 | 03:43 PM
CarlessAndy's Avatar
CarlessAndy
Default COnvertable top Adjustment
I have a 96 Convertable and the drivers side when latched closed leaves 3/8-1/4 in space and leaks water. I see that the hook is threaded, is that how to tighten it down?
Thanks,
Andy
Old Apr 22, 2005 | 04:30 PM
YinYangStang's Avatar
YinYangStang
Default RE: COnvertable top Adjustment
yes...look closely at both sides of the hook though, there should be a small screw, mine has a little hexagonal nut that you have to unscrew first before you can adjust the hook. Also check to ensure the small pole on the top that slips into the slot on the top of the windshield is screwed down tightly as well.
Old Apr 22, 2005 | 05:47 PM
Marty256's Avatar
Marty256
Make sure to check the weather stripping also. Not likely that the top went out of adjustment. More likely the weather stripping is damaged.
zsmart
Convertible Tech
Feb 29, 2016 08:33 AM
GPR
Dec 16, 2015 12:21 PM
LivingInThePast
Sep 16, 2015 12:20 PM
kawiguy827
Sep 1, 2015 07:09 PM
