failed inspection
Old May 9, 2008 | 07:55 PM
ride_maine's Avatar
ride_maine
Default failed inspection
hey guys, i just failed inspection on my 97 cobra because I have worn tie rod ends. There is a good amount of play when moving the wheels and its quite noticeable while driving too since the car isn't tracking straight and the steering isn't responsive. So my question is which ends should I buy, I hear this is no place to cheap out. If one's from like Autozone or Advanced Auto Parts aren't good enough what will better ones cost, what size shank, bore, etc should they be. What angle is a typical rod end for this car and how tight do they need to be torqued? I believe there press in and not sealed bearings so do I still need to use a special puller tool? Sorry for the easy questions and long post but I don't have a manual and I've never replaced these on a car before. Thanks so much.
[/align]
Old May 10, 2008 | 01:15 AM
Stepman's Avatar
Stepman
Default RE: failed inspection
Get something in "Moog". they are good parts and available most places. Don't remember the torque, but think it's only like 30 lbs or something. You don't need special tool, just loosen nut and hit the spindle end with a hammer a few times usually breaks them loose. You will need to have your "toe-in" reset afterwards though.
Old May 10, 2008 | 05:32 PM
sYckmYnded's Avatar
sYckmYnded
I ♥ Acer
k im a lil lost,, there is no bearing or nothing on your tierod end, simply count the threads that u can see and pop off the castle nut flip it around and gently hit the nut from below till the rod pops from its seat then unwind the end off the shaft , the moog is a great brand and a life time warrenty and you can get them at autozone napa or any parts store, when you put the end back on turn it down till you have the same number of threads showing on the rod then pop it back in its seat and tighten the castle nut down as tight as u can by hand then adjust to line up the cotter pin hole, replace cotter pin!!! then drive to you local tire shop for a front end alighnment asap.. have fun, its a easy job
jwog666
Dec 27, 2021 08:09 PM
baddog671
Jul 26, 2016 01:20 PM
GLOCKer
Sep 28, 2015 07:36 AM
prophotog
Sep 15, 2015 08:38 AM
TfcCDR
Sep 14, 2015 12:08 PM
