engine conversion(changed)
Old May 11, 2008 | 07:07 PM
newpony's Avatar
newpony
Default engine conversion(changed)
if i bought a small block 427(shortblock) ford
can i use mu intake manifolds and heads(will they bolt right up)
Old May 11, 2008 | 07:12 PM
my little red 90's Avatar
my little red 90
Default RE: supercharging hp
NO!
Old May 11, 2008 | 07:27 PM
newpony's Avatar
newpony
what will i need .....
Old May 11, 2008 | 10:06 PM
Tha Boss's Avatar
Tha Boss
900 hp you need a completely new block. A stock block wont handle 900 hp regardless of wat u do to it. You need a race block. You can get a 302 race block for about 1800 bucks.
Old May 11, 2008 | 10:09 PM
Tha Boss's Avatar
Tha Boss
Also for 900 hp you need a good quality bottom end(pistons, rod, crank) the whole nine. That is a lot of hp you are trying to produce. Hope your budget is very loose.
Old May 16, 2008 | 06:39 PM
newpony's Avatar
newpony
whats the max hp the stock engine can take
Old May 16, 2008 | 08:16 PM
my little red 90
never having tried to reach the limit, i do not know.
some people that should know say in the 600+ range. car craft did a 408ci to 611hp.at that level life is probably relative short.
Old May 16, 2008 | 08:29 PM
newpony's Avatar
newpony
my 87 has 225hp and i was looking at a paxton supercharger that said it adds 45-65% hp thats a average of atleast 50% which would put my hp range around 320hp my plan it to get atleast 375 reliable hp
at 45%(49) its arount 7 lbs of boost correct me if im wrong .....with a supercharger like paxton (centrifugal) how do you turn up the boost
the description says that it will only give you a max of 275 at 6 psi
http://www.jegs.com/i/Paxton/769/1001831/10002/-1
Old May 16, 2008 | 08:37 PM
ryan1994mustang's Avatar
ryan1994mustang
you change the boot by different size pulleys...a smaller diameter pulley is going to turn quicker, therefore producing more boost, and a larger pulley is just the opposite. and when installing a blower, you are probably going to want to add a few bolt ons as well to maximize the performance of the blower, and MAKE SURE you get a good dyno tune. as a general idea, the more boost you are pushing, the les reliability you will have. from what i have heard, about 9psi is about as much boost as you want to put on a stock bottom end.
Old May 16, 2008 | 08:56 PM
newpony's Avatar
newpony
2,000$ for 50 hp just dosent sound right
