Reverse Glow Gauge Problem
Old Apr 30, 2005 | 03:19 AM
02StangGT's Avatar
02StangGT
Default Reverse Glow Gauge Problem
I installed reverse glow gauges in my 02 GT a few months ago and everything was fine until last week. They started flickering and occasionally just went out completely. I took it apart to check my power and my ground and they both seemed fine. If anyone else has had this problem or can help I'd appreciate it. [sm=dontgetit.gif]
Old Apr 30, 2005 | 01:09 PM
babygurl2000's Avatar
babygurl2000
I ♥ Acer
Default RE: Reverse Glow Gauge Problem
flickering?
i had that same problem until Dave just fixed it lastnight. he wired them direct.
they are wired right into the parking lights.
mine was in a temporary fix until i got my switch for my driving lights.
lastnight Dave came out and fixed everything.
mine used to flicker when i used anything else while i was driving.
roll window down *flickered* use wipers *flicker*
but problem solved now.
Old May 2, 2005 | 11:39 AM
DIVER8374's Avatar
DIVER8374
I have them and wired them directly to the headlight switch, and have not had any problems with mine. What are you useing to power them?
Old May 2, 2005 | 02:17 PM
babygurl2000
I ♥ Acer
yeah i had Dave wire mine direct now too. hey did he answer your email ? problem fixed?
update plz..
Old May 3, 2005 | 10:12 AM
02StangGT's Avatar
02StangGT
I haven't heard from Dave yet. The way I have mine wired now is the power is soddered to the blue wire coming out of the headlight switch? Which wire did you guys hit for your power?
Old May 3, 2005 | 10:49 AM
babygurl2000
I ♥ Acer
i just asked him again. he is at work so hang on and i will have the answer for you ok?
Old May 3, 2005 | 11:02 AM
DIVER8374's Avatar
DIVER8374
I don't remember what wire I used, but it is very easy to find the correct one. If you have a volt/ohm meter, just put one prong on a good ground, and use the other one to insert into the back side of the plug. now turn on the lights and see if the volts jump up, if they do, shut it off and see if it drops down to 0. once you find a wire that does this that is the wire that you want to connect it to. Hope this helps ya.
Old May 3, 2005 | 11:11 AM
02StangGT's Avatar
02StangGT
I did the same thing with the volt/ohm meter and found the blue wire to be hot. Is there maybe multiple hot wires going into that headlight switch with higher/lower currents? Maybe I just picked the first one that I found instead of the right one. I'm still confused though b/c the gauges are getting power, they're just flickering like it's a bad connection or something. I soddered it wire to wire though so I have no idea. I used a stainless steel screw to tie my ground to the metal behind the gauge cluster so I'm pretty sure it's got nothing to do with my ground.
Old May 3, 2005 | 11:19 AM
babygurl2000
I ♥ Acer
http://www.v6stangs.com/index.php?pa...uges/index.php
right here is your instructions.
YES it is a brown wire off your switch..
mtgldr
Feb 3, 2024 09:00 PM
MusicCity615
Sep 12, 2015 07:05 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
96stang3.8
Sep 10, 2015 06:42 AM
raleigh05GTO
Sep 4, 2015 07:09 AM
