wandering 69
Old Jul 20, 2008 | 07:07 PM
madundertaker's Avatar
madundertaker
Default wandering 69
Help me please. I have a 1969 Mustang coupe that has a wandering problem when I drive it. It's not bad at slow speeds, but at about 50mph. it starts to get a little scary. It does have power steering and it is full of fluid. I've been told it could be in need of a steering box or maybe just a simple adjustment. Either way it needs to be fixed. Where should I start and will it be an expensive fix?
Old Jul 20, 2008 | 09:40 PM
TripleHmotosports's Avatar
TripleHmotosports
Default RE: wandering 69
How old are the front end components? ie; (tie-rods,ball joints etc) I would start there first to make sure everything is in good shape. There is an adjustment that can be made on the steering box to tighten it up if that is the problem.You could take it to a front end shop and have it inspected to seewhat the problem is.
Old Jul 20, 2008 | 10:22 PM
LateNiteTV's Avatar
LateNiteTV
wandering... like pulling to one side? or going every which way?
Old Jul 21, 2008 | 08:04 AM
Chopper's Avatar
Chopper
I figure it's a combination of worn front end parts and a need for a front end alignment.
Bushings,ball joints,tie rod ends,and maybe bearings can get pretty expensive but if you're going to keep the car I'd use good quality parts.
Professor Wizard
Mid West
48
May 7, 2007 01:02 PM
odiaz
Oct 31, 2005 12:33 AM
95stang5.0
Aug 25, 2005 10:51 AM
msarcheck
May 11, 2005 10:49 PM
BYA02
Feb 15, 2005 07:59 PM
