Thumping noise
Old Aug 10, 2008 | 09:50 PM
mikehands's Avatar
mikehands
Default Thumping noise
I have Tokico shocks/struts on my '06 GT. When I drive the car I hear a thumping/rattling sound from the front passenger side. I bottomed out the adjustment and backed off two turns, but I don't think the problem is the adjustment, because it happens no matter where I set it. Jacked up the car thinking it was loose exhaust, but it's not. Is much more noticable when I hit a pot hole as opposed to a bump. All body kit fasteners are tight, as are the break calipers. Removed the front wheels, but all is correct. I'm stumped...
Old Aug 13, 2008 | 07:30 AM
sik.kid's Avatar
sik.kid
check to see if the brake pads sit tight on the caliper studs mine chatters a bit when i go over bumps and it stops when* the brakes are pressed slightly and check tour ball joints for loosness it could also be the wheel hub and bearing assembly
Last edited by sik.kid; Aug 13, 2008 at 07:33 AM. Reason: wheel hubs are important to keep an eye on due to potential safety hazards
bjdutch2005
Mar 24, 2017 03:38 AM
KingRando
Oct 2, 2015 08:06 AM
Ghost_Conscience
Sep 23, 2015 02:17 PM
ccdguy
Sep 19, 2015 05:20 PM
