Need help wiring up Halo Headlights
Im stuck , I can figure this out , there a 4 wires total ( a red and black wire on the very inside ) then the wiring harnness that has 2 red wires , isn't one of those supposed to be ground ? ( its actually 2 red wires & 2 white wires that come out into to red wires ) I wired up all three red to middle parking light connector ( brown wire ) and the one black wire to the balck ground wire on parking connector . take a look at pics and tell me whats wrong?thanx
I bought these off ebay and it was more work than expected. there are four wires yes, the halo high, the halo low, the little lights in middle and the ground. we actually wired them in to the harness-i was told not to use those quick connectors you got pictured-they sometimes work loose after a while causing a poor connection...good luck...you can find more detailed installation directions just googling it.
jwog666
12-27-2021 08:09 PM
Matt's 95 Stang
10-05-2015 07:16 AM
