outer tire wear
Old May 17, 2005 | 03:31 PM
vitiris's Avatar
vitiris
Default outer tire wear
I have a 98 Mustang on which I've replaced the tires once. On the stock tires, there was outer tire wear on the front tires: so much wear that the inner still showed great thread. It's that time again to change tires due to this tread. Why is this happening on the outside of the front tires?
thanks
Old May 17, 2005 | 03:32 PM
mkspeed26's Avatar
mkspeed26
Default RE: outer tire wear
ur alignment is way off. get it aligned
Old May 17, 2005 | 03:35 PM
Djs94stang's Avatar
Djs94stang
Too much positive camber. You can adjust it a little while stock but to do anything major you'd need to add camber plates.
Old May 17, 2005 | 03:58 PM
MikeHawke's Avatar
MikeHawke
Retired MF Moderator
outside wear is unusual on these cars. You definitely need an alignment.
Old May 17, 2005 | 06:02 PM
vfast's Avatar
vfast
I ♥ Acer
to much toe in
Old May 18, 2005 | 09:06 AM
Leadfoot's Avatar
Leadfoot
I'm surprised whoever replaced your tires didn't suggest an alignment right off. If they didn't, they didn't know what they were doing because now you have cut down on the life of the tire.
Old May 18, 2005 | 11:59 AM
stanglx2002's Avatar
stanglx2002
you need to take you r car and get it realigned
Old May 18, 2005 | 02:52 PM
Deannostang's Avatar
Deannostang
Alignment, low air pressure and continuous hard cornering will all contribute to premature outer tire rim wear. Does sound as though your alignment is way off.
jwog666
Dec 27, 2021 08:09 PM
CS2007
Jun 25, 2019 09:45 PM
KingRando
Oct 2, 2015 08:06 AM
marc954
Sep 29, 2015 11:18 AM
nmra1965
Other Professional Racing
Sep 26, 2015 10:46 AM
