posi unit
Old May 22, 2005 | 03:45 AM
white_snake's Avatar
white_snake
Default RE: posi unit
ORIGINAL: 99saleen351r
Sorry man i thought you just couldnt drive looks like a gt from the back,you should be all set then with that peice looks to be all you need
naw i cant really drive that is why i bought the auto lol, j/k didnt look hard enough for a standard.
Old May 22, 2005 | 03:48 AM
white_snake
[/quote]
i dont know if it has the 3.73 but i can always buy those later right?
[/quote]
damn im stupid, ya it does say 3.73 gears[:@] sorry for the dumb posts
im all set then...is that a good deal, if it does go up to 200$?
Old May 22, 2005 | 11:34 AM
99saleen351r's Avatar
99saleen351r
I was wondering why you said that I'm looking at it like "what the hell is he talking about" Ya thats a deal the gears will cost ya 200 plus the carrier is 400 so as long as it doesnt go over say 400 its a deal ,you'll have to have someone put it in though because i believe it has to be re shimmed for your car[:@]
Old May 22, 2005 | 11:48 AM
white_snake
what do you mean re shimmed?
and what is the carrier?.
i dont know crap about rear ends.
thanks for your countinuded help.
Old May 22, 2005 | 11:52 AM
99saleen351r
the carrier is what holds the spider gears and the ring gear,the small gear is called a pinion gear when you insatll that it has to be shimmed so that it touches against the ring gear perfectly or else it will break off all the teeth on the pinion gear.The pinion gear is the one thats sticks out the front of the rear end and connects to the driveshaft if that not shimmed right with a dial indacater it will whine or have a ton of backlash so when you let off the gas it will clunck like there is play in the rear end, Not good
Old May 22, 2005 | 11:54 AM
99saleen351r
Check this out http://www.superstallions.com/tech/d...ars/gears.html might help explain
baddog671
Jul 26, 2016 01:20 PM
kevsgt
Oct 9, 2015 10:12 PM
lincolnshibuya
Oct 6, 2015 08:45 AM
jrrhd73must
Oct 2, 2015 09:17 PM
TorinoCobra070
SVT Forums
Sep 18, 2015 10:34 AM
