a/c compressor
Old Oct 16, 2008 | 05:37 PM
bradplock's Avatar
bradplock
Default a/c compressor
okay, just confirming. my compressor doesnt spin, so i jumped the low pressure switch. still nothing. am i understanding right, that the compressor will only turn while being jumped if there is enough pressure in it? so could that be the reason mine is not turning? not enough R134A? the fuse is good. also, i've never heard of anyone jumping the high pressure switch, will this do no good? anyway to diagnose clutch or even a complete lock up?
Old Oct 16, 2008 | 07:00 PM
Chopper's Avatar
Chopper
Here's a link that might help you out.
http://www.autoacforum.com/categories.cfm?catid=2
I would think the compressor would turn if there is electrical power to the clutch regardless of the state of charge of the A/C system.
I had a line come disconnected while decorating the street in front of my house one day and I just reconnected the line and hooked up a can of R 134-A.I used the first can and the compressor came on and I refilled the system normally.
One thing you DO want to watch out for if you do the work yourself is the amount of lubricant you put into the system.Too much and the efficiency is reduced and the compressor will run continuously instead of cycling on and off.I might have done this myself but I didn't need the A/C very much this year so I didn't really check it out,,,yet.
vargas
Jun 17, 2017 12:17 PM
fastbackford351
Oct 1, 2015 12:24 PM
69Volunteer
Sep 30, 2015 10:39 AM
fastbackford351
Sep 12, 2015 09:42 AM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
