clutch noise
Old Oct 28, 2008 | 10:14 PM
04gttang's Avatar
04gttang
Default clutch noise
the clutch in my 04 gt is making a whining sound i guess you could call it that only when i press in the clutch and it feels like when i am pulling out in first that it doesnt want to pullout.....it used to almost pull out itself now i have to give it alot of gas.....could this be a clutch going out or just something else that i should check out first......it has 73,000 miles and i dont know if its a stock clutch or what or if it has been changed i bought it used any help would be greatly appreciated.....and if it is the clutch what kind would be the best to replace it
Old Oct 31, 2008 | 09:44 AM
04gttang's Avatar
04gttang
any help would be appreciated i know someone has surely had some clutch problems.....
Old Oct 31, 2008 | 09:47 AM
R-code17815's Avatar
R-code17815
Sounds like the clutch is starting to give up the fight.
Old Nov 1, 2008 | 01:17 PM
abingdonmustangs08's Avatar
abingdonmustangs08
when you say it dosnt want to pull out do you mean you have to release the pedal almost all the way out before it grabs???? Or like the pedal is sticking??????
Old Nov 2, 2008 | 06:47 PM
04gttang's Avatar
04gttang
its almost all the way out before it grabs
Old Nov 3, 2008 | 10:53 AM
zippo2341's Avatar
zippo2341
sounds like the clutch is definately shot, centerforce makes good stuff. i put a stage 2 in mine and it has alot of bite. when and if you have it replaced, do everything. the clutch, pressure plate, through-out and pilot bearings. have the flywheel resurfaced as well for good measure. you can take that to a machine shop and usually costs $30. also replace the tranny fluid. if your not going to do this yourself you can have a good reputable shop do it for you. to have a shop do it it could cost around $750 with parts. but all depends on who you go to.
Old Nov 7, 2008 | 02:12 PM
04gttang's Avatar
04gttang
ok now when i press in the clutch it sounds like a belt is squeaking.....and when i let the clutch out it stops.....i hope its not the whole clutch cause i cant afford to drop that kind of money right now.....could it possibly be something to do with just the clutch cable or the quadrant???
Thunderball
15
Nov 22, 2015 11:49 PM
KingRando
Oct 2, 2015 08:06 AM
junior04
Sep 28, 2015 10:53 AM
MacSerio
Sep 27, 2015 01:05 PM
ccdguy
Sep 19, 2015 05:20 PM
