93 mustang stalling problem......
Old Nov 1, 2008 | 02:35 PM
dstang88's Avatar
dstang88
Default 93 mustang stalling problem......
I have a 93 mustang lx.....its a 2.3 with a automatic transmission. I can start the car fine an it will idle fine in park. If i put the car in drive or reverse then it will die. Its like the torque converter is locked up or something. It feels like having a manual car an putting in first without using the clutch, just die
Old Nov 1, 2008 | 07:09 PM
dstang88's Avatar
dstang88
any ideas.............heres some more detail.........I was on my way to work an was coming to a red light an it died when i came to a stop, like not pushing the clutch in on a manual. I needed to get out of the road, i started it back, put in drive an died. I tried it again an this time reved it up an it bumped into drive an i got to a pull off. I sat there for a minute an started it up an put it in drive but nothing. I wouldnt move. I could rev it up to about 5000 rpm an move maybe 5 mph. I sat there for even longer an needed to get down the road. So i reved it at 5000 rpm moving only maybe 5 mph an moved a pretty good way an then bam it started going just fine all the way to the house. If i came to a stop on the way it would die an would have to rev it an move untill it started again. Now its home an i cant even move it. Everytime i put it in gear it dies. In park it will run ok, it just seems to have a vibration when it idles but not a bad one. The trans fluid is good.....but im thinking i might have caused the problem now the more i think. The old a4ld slipped real bad an i had this one laying around so i put it in. My car is a 93 an i swapped in a older a4ld out of a mustang. The lockup on the side of the trans from the one i pulled was a 3 wire connector. The one i put in was a 2 wire, I just matched up the colors an left one wire unhooked. It seemed fine.....drove the car for a month an hafe with no problems an now this. I have tried unhooking it, disconnecting the battary. What do you think is wrong with my car? The torque convertor? Engine problem? Trans problem?
Old Nov 1, 2008 | 07:12 PM
dstang88's Avatar
dstang88
any ideas.............heres some more detail.........I was on my way to work an was coming to a red light an it died when i came to a stop, like not pushing the clutch in on a manual. I needed to get out of the road, i started it back, put in drive an died. I tried it again an this time reved it up an it bumped into drive an i got to a pull off. I sat there for a minute an started it up an put it in drive but nothing. I wouldnt move. I could rev it up to about 5000 rpm an move maybe 5 mph. I sat there for even longer an needed to get down the road. So i reved it at 5000 rpm moving only maybe 5 mph an moved a pretty good way an then bam it started going just fine all the way to the house except a slight vibration. If i came to a stop on the way it would die an would have to rev it an move untill it started again. Now its home an i cant even move it. Everytime i put it in gear it dies. In park it will run ok, it just seems to have a vibration when it idles but not a bad one. The trans fluid is good.....but im thinking i might have caused the problem now the more i think. The old a4ld slipped real bad an i had this one laying around so i put it in. My car is a 93 an i swapped in a older a4ld out of a mustang. The lockup on the side of the trans from the one i pulled was a 3 wire connector. The one i put in was a 2 wire, I just matched up the colors an left one wire unhooked. It seemed fine.....drove the car for a month an hafe with no problems an now this. I have tried unhooking it, disconnecting the battary. What do you think is wrong with my car? The torque convertor? Engine problem? Trans problem?
fdnyems19
Aug 13, 2015 09:36 AM
stanngg
Aug 12, 2015 03:43 PM
daytooday
Aug 11, 2015 09:22 AM
01blackgtconv
Aug 10, 2015 01:25 PM
