Rebuilding the top end.
Old Feb 2, 2009 | 10:09 AM
01GTDropTop's Avatar
01GTDropTop
Exclamation Rebuilding the top end.
My brother's 97 F-150 was pouring out white smoke and had a knocking sound come from the top end. I tore everything down to the short block. I found a little rip on the intake manifold gasket but still removed the heads just in case. The head gaskets were fine. I took the heads to a shop to be checked out and cleaned. He had some milkshake inside the intake manifold and passenger side valve cover. A friend has told me put everything back together and let it warm up. Replace oil. Then replace oil several times for about 5,000 or so miles.
Now I have done some mechanical work with bolt ons and routine replacements of engine parts. I have not done anything this far before. It seems to be a simple tear down and rebuild. What are some things that I am looking forward to upon putting everything back together? Can I still use the same rods (that are in a perferated box in order)? Will I have to wait for it to turn several times to build pressure to restart?
Comments much appreciated, Thank you.
Phil
Old Feb 2, 2009 | 11:33 AM
Fobra's Avatar
Fobra
Banned
so your going to rebuild it completely... you need to get a manual and it will explain all the things that can and cannot be reused and things that should be replaced
Old Feb 2, 2009 | 02:54 PM
01GTDropTop
No, not a complete rebuild. I just removed the Intake pleneum (sp?), intake manifold, and heads. And a whole bunch of wire connections, haha. (which are labeled)
I was asking if I can reuse everything and put it back together. I know to replace the head bolts and gaskets, but can I use everything thing else. My brother does not have the money to do a costly rebuild, nor do I. I have a manual to the truck, but wanted the opinion and advice from y'all as well.
BTW, it's a 4.2L V6.
lincolnshibuya
Jul 5, 2020 03:05 AM
flash_xx
Oct 16, 2015 07:23 AM
Bokeo
Oct 10, 2015 08:28 PM
Dathan
Oct 5, 2015 05:52 AM
Drastang
Sep 30, 2015 03:48 AM
