unusual noise
Old Jun 16, 2005 | 06:23 PM
Darkhan's Avatar
Darkhan
Default unusual noise
Recently while driving, i've noticed an unusual noise coming from underneith the car. Since having an aftermarket exhaust system, it can make hearing the noise a little difficult but it is easy to distinguish nevertheless. The noise is a low rumbling or rubbing (grinding sound) and cannot reproduce it upon request. It does not happen during idle or revving the engine in neutral. It is not exclusive to up-shifting or down-shifting or at different speeds or turns which can make this frustrating. I have isolated the noise coming from underneith the driver side console and have isolated anything in the interior causing the noise. I have had no problems with my aftermarket exhaust system and have installed the system myself completing everything 18months ago. The car drives and handles fine at all speeds and gears.
I spent approx. 2 hours under the car doing a quick inspection checking the headers for any loose bolts or leaks. I shook on the entire exhaust system and could not find any anomalies. I have tested the clutch by having it at idle and pushing in the clutch to hear the change in the engine - which sounds normal. The only thing I noticed that I could not identify was a penetration in the driver side firewall approx. 4" above the exhaust manifold (headers in my case). It appeared to be some sort of drain with no connection in the proximity of the opening. It does however, drip onto my headers.
I do drive the car hard at times (it's a mustang - heh) but take gentle care of it. My suspicions are leading me to my U-joint but with only 20k on the odometer, it strikes me odd. I haven't checked them as of yet but wanted to post this to see if there are any other ideas of where to place my concern.
Any help would be much appreciated.
Old Jun 17, 2005 | 03:41 PM
99saleen351r's Avatar
99saleen351r
Default RE: unusual noise
Are you sure the exhaust isnt rubing the driveshaft???The dripping your talking about is condesation from the Ac condeser there is tube the water drips from out of the heater box
bjdutch2005
Mar 24, 2017 03:38 AM
KingRando
Oct 2, 2015 08:06 AM
69Volunteer
Sep 30, 2015 10:39 AM
Ghost_Conscience
Sep 23, 2015 02:17 PM
