Rear End swap gone bad??
Old Jun 2, 2009 | 06:57 AM
foxbodypusha's Avatar
foxbodypusha
Exclamation Rear End swap gone bad??
Okay I hope this is an easy fixer. I have an 88 gt hatchback 5 speed with the 8.8 with the quad shock setup. I recently blew ethe rear end out and i picked up a rear end with 373 traclock. Anyway I didnt notice until i was trying to mount the new rear-end that it does not have the mounting brackets for the addittional struts (dampners) How would i go about diagnosing this?? will this not work or is there some kind of adapting type brackets?? i tried to find a casting number or something to identify the year of the axle and i believe it was built in 1993 ( according to the brake line divider mounted on the top of the axle.. thanks please help me!!
Old Jun 2, 2009 | 10:19 AM
mudvayne1's Avatar
mudvayne1
Take a torch and cut the brackets off your old rear end and weld them to the new one.
Old Jun 2, 2009 | 10:39 AM
Gary H's Avatar
Gary H
If you have aftermarket lower control arms you dont need them.
Old Jun 2, 2009 | 02:11 PM
foxbodypusha
Default control arm??ble
Okay so if i purchase aftermarket lower control arms it will slide into place?? Do they have to be adjustable or what would you suggest? this is if i cant get the old brackets off and re-welded on ofcoarse. thanks
Old Jun 2, 2009 | 05:01 PM
Gary H's Avatar
Gary H
You dont NEED the quad shocks, you'll just get some bad wheel hop if you launch it hard.
91StangOwner
Aug 20, 2015 11:34 PM
Black_GT_02
Aug 20, 2015 01:26 PM
ding56
Aug 14, 2015 02:40 AM
92 5.0stang
Aug 13, 2015 06:46 AM
PearlGenPu
Aug 12, 2015 01:57 PM
