Question about a Ticking noise
Old Jul 27, 2009 | 08:52 AM
badboyjjd's Avatar
badboyjjd
Default Question about a Ticking noise
SO Mustang lovers I am wondering if anyone call help with this one. My 06 stang GT is making a ticking/clicking noise. It seems to only be when I turn the AC on. And If it is on It repeats the noise approx every 16 seconds. A buddy of mine told me it is a compressor. Maybe a faulty one, or defective. Or should it make this noise. Do all stangs make this noise. It is heard easily, its not in my head. It is most definitely there. I am just wondering if its normal. So far it doesn't appear to make a preformance difference. ALthough I do also notice a bit of over all power decrease when the Ac is on. but again it is a drain off the battery so not to out of the norm. Please folks your comments are wanted and appriciated!
Maximum Boost inside the ride.
JJD
Old Jul 27, 2009 | 09:50 AM
socalwrench's Avatar
socalwrench
Is it possible you are referring to the A/C compressor turning off and on?
Ford uses a fixed orifice tube (FOT) type of A/C system which cycles the compressor to keep operating pressures where it needs to be. The clicking noise is the compressor clutch engaging and then disengaging.
Also, you will notice a slight power loss when the compressor is engaged (as it puts a load on the engine). There should not be an excessive drain from the battery, but you may notice a small voltage change as the clutch uses a small amount of voltage (and current).
Old Jul 27, 2009 | 11:04 AM
GreyStang's Avatar
GreyStang
Pop the hood open & WATCH the A/C compressor while it is running. Do you see it doing anything at the moment of the ticking sound?
Nick Oliver
Oct 17, 2018 04:22 AM
bjdutch2005
Mar 24, 2017 03:38 AM
04stangman
Sep 17, 2015 01:45 PM
Emblazoned
Sep 3, 2015 10:45 PM
