Is this Normal?
Old Jul 5, 2005 | 06:03 PM
Zachv1's Avatar
Zachv1
Default Is this Normal?
Hey, I just re-built my motor in my 94GT and threw on heads, cam, and intake while i was at it. Once I got it all together I fired it up and set the idle to about 1000 rpms. The only problem was it kept taking it a while to find idle. Whenever i go to start the car it will fire up, but i have to either keep revving it or hold it at about 2000 rpms for about 2 to 3 minutes before she will sit at idle, and if i dont do that she will just die. I dont think it has anything to do with vacuum leaks either because once she warms up after the 2 to 3 min. of revving she runs fine. I think it may have something to do with my cam, but if anyone knows for sure please let me know. I also installed a new MSD dis. and i was also wondering if i installed all this stuff and am running higher comp.(about 9.5:1) if my timing should still be about 14* or if it needs to be retarded some. Thanks,
Zach
Old Jul 5, 2005 | 06:09 PM
Quik's Avatar
Quik
Default RE: Is this Normal?
seems like you need a tune
Old Jul 5, 2005 | 08:56 PM
cammedlx's Avatar
cammedlx
Try to drill a small hole in the throttle body butterfly since that has been known to fix idle problems and hard startup's on cammed stang's.
Old Jul 6, 2005 | 02:13 AM
94Cbra's Avatar
94Cbra
I think I would try a tune before I started drilling!
Edit: What the hell is wrong with me? You said somthing about a cam so I'm assuming you have a more radical cam. 94-95 computers are total JUNK. They dont respond well at all to even a mild camshaft application. You need a custom chip and tune, that'll fix your problem.
FivePointToTheOh
Mar 9, 2020 10:26 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
breaking
Oct 2, 2015 01:27 PM
guitarman376
Sep 30, 2015 05:54 PM
96stang3.8
Sep 10, 2015 06:42 AM
