overheat when AC is on
Old Jul 10, 2005 | 04:16 AM
blazer_4.3's Avatar
blazer_4.3
Default overheat when AC is on
friend of mine has a 97 cobra. last week his "check engine" light came on, didnt think anything of it at first. then he noticed whenever he turned AC on, his temp would almost get in the red area. today he took out his thermostat hoping that would slow the affects. he said that did nothing.
he has an APPT this thursday with a mechanic, but i was hoping u guys could lead us in the right direction b4 he spends bookoo bucs on diagnosis.
any suggestions welcome, thanks in advance.
brian
Old Jul 10, 2005 | 12:41 PM
99saleen351r's Avatar
99saleen351r
Default RE: overheat when AC is on
Does it have 2 fans one for the motor and one for the Ac??If it does the second might not be turning on
Old Jul 10, 2005 | 03:03 PM
blazer_4.3's Avatar
blazer_4.3
yeah i thought the same thing, cuz that is how my car is. but he popped his hood and it only has one fan. he said it he had checked it already and it works.
any other suggestions?
Old Jul 11, 2005 | 12:55 AM
fordguy17's Avatar
fordguy17
well, the a/c compressor itself put added stress on the motor, and it also put more heat into the cooling system by way of the condensor.
obviously his cooling system is not up to par. flush the radiator and refill it with 70 percent water and 30 percent coolant and throw in a bottle of water wetter. put in a new 180 thermostat and makes sure the cooling fan turns on at the right time.
Old Jul 11, 2005 | 03:36 AM
73Cleveland's Avatar
73Cleveland
ORIGINAL: fordguy17
Good advice! This should help a lot!
Old Jul 11, 2005 | 08:36 PM
mmoto68's Avatar
mmoto68
I have a '95, there was a recall on the fan relay.
Sometimes when the a/c was on or it got really hot, the car would overheat.
The fan is wired for a low speed and a high speed (12 and 14 volts(?)) setting. Your friend can check to see if he is getting power to the fan when the a/c is on. If he's not, it's probably the relay.
Before I found out about the recall, I put in a switch to manually turn on the fan.
Old Jul 11, 2005 | 10:56 PM
blazer_4.3's Avatar
blazer_4.3
alright thanks alot guys. i will give hyim a call here in a few and see what happens. hopefully one of the two u say is the culprit. either way i let u know.
thanks again, brian
Daveyboy
Aug 4, 2006 04:29 AM
Mac 108
Jul 25, 2006 01:23 AM
ok_ee
Jun 27, 2006 08:27 AM
fastmfer
Sep 30, 2005 02:29 PM
camocreek
May 25, 2005 02:18 AM
