95 Convertible does not go up ???
Old Jul 15, 2005 | 07:49 PM
tonym10's Avatar
tonym10
Default 95 Convertible does not go up ???
I have a 1995 Ford Mustang GT covertible. The top goes down, but it does not go up. Does the motor just wear out and is not able to bring it back up? Does the convertible motor need to be replaced and if so, does anyone know how expensive this is, and how big of a job it is?
Thank you
Tony
Old Jul 15, 2005 | 08:23 PM
GreyStang's Avatar
GreyStang
Default RE: 95 Convertible does not go up ???
What does it do when you try to raise the top? Can you hear the motor "trying" to raise it?
How do U wind up getting the top to go up?
Old Jul 15, 2005 | 09:06 PM
tonym10's Avatar
tonym10
I do not here anything, but that doesnt mean anything, I do not hear the motor when it goes down. I do not know if maybe it is in the switch?
I had to pull the top slowly. Was difficult.
Old Jul 16, 2005 | 03:50 AM
Lazarus's Avatar
Lazarus
I had the same problem in my 95 GT and it was in the motor that raises the top. You should get it fix soon because raising the top your self can wear out the gears, at least this is what I was told by my mechanic because I found out that it wouldn't go up after it was already down and had to manually raise it, also. It'll take a couple hundred bucks depending on the severity of the problem. Sorry, I can't really remember the exact amount.
Old Jul 16, 2005 | 06:13 PM
Leadfoot's Avatar
Leadfoot
Where did you go to get the top fixed?
Luckily I never had that problem. How do you manually put it up just in case I have to do it too?
Old Jul 17, 2005 | 12:36 AM
Lazarus's Avatar
Lazarus
My car dealer knew a mechanic who knew Mustang convertible motors well.
To put it up manually, just grab it and pull it up. It's really hard to pull but with a little work, you can get it up. Better than leaving it down, in my opinion!
Old Jul 18, 2005 | 10:22 AM
Leadfoot's Avatar
Leadfoot
Would it be a good idea to have somebody push the button that is normally used to put the top up? This way you aren't really forcing the top.
I would think that just pulling the top would hurt whatever is left of the mechanism.
Old Jul 18, 2005 | 02:09 PM
tonym10's Avatar
tonym10
I tried having the switch held while manually raising the roof, it did not do anything.
But today we removed the switch to see if maybe it was just a bad contact in the switch, and sure enough it was, we just removed the switch opened the switch, put it back together and the roof works fine, got lucky I guess.
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
lovesilver
Members Mustangs
May 9, 2019 09:18 PM
jerrytubes
Oct 23, 2015 12:11 PM
guitarman376
Sep 30, 2015 05:54 PM
