Car Maintenance Tips
Old Dec 15, 2009 | 03:23 AM
yana's Avatar
yana
Banned
Default Car Maintenance Tips
hese tips will surely prolong the life of your car and ensure a smooth and effortless drive.
Car Air Conditioner
Air Conditioner is an integral part of any car really taking care of the comfort of the passengers. Proper functioning of air conditioner is definitely a thing of importance for the comfort of the occupants of the car. While driving in hot and humid weather, an efficient air conditioner is must.
Car Brakes
Brakes are, of course, the most vital safety component of a car. And it is mandatory for your own security that you keep the brakes of your car in best condition. Break problems do not rise to a serious level suddenly. Most brake problems develop gradually and if the system is detected properly, these can be detected before they become serious.
Car Cooling System
Cooling system in a car protects the engine from overheating. An efficient cooling system to keep the engine protected. One must always use good quality coolant for car engine. The coolant level must be checked at least once a fortnight. During summers, it must be checked and preferably at more frequent intervals during summers.
Car Engine
When it comes to a car, the most important component is the engine. The engine can well be regarded as the soul of a car. In fact, you might have the most well-maintained and sparkling set of wheels in your neighborhood, but if its engine is not working, it is as good as waste. In order to make sure that your car has a long life,
Car Fuel System
One of the basic components of a car comprises of its engine and talking about the car engine, its fuel system needs to properly taken care of. In fact, proper car maintenance is as good as incomplete without adequate maintenance of the fuel system.
Car Gears
Gear system forms an important component of a car and thus, requires proper handling and attention on your part. Since they help you maintain the speed of your car; you cannot afford to misuse the gears. While changing the gears, it is very important that clutch should be completely pressed. At the same time,
Car Tyres
Though a large number of car owners are unaware of the fact, car tyres have an important bearing on the performance and safety of the car. In fact, when car maintenance is the question in point, ensuring a good condition of the tyres is an issue that occupies a central place.
Car Electrical System
Has you car ever got stalled midway due to electrical faults? Such a scenario is quite frustrating, isn't it? However, proper maintenance of the electrical system of your car can go a long way in ensuring that it gives a trouble free performance in each and every drive.
Car Alternator
The alternator produces electricity used to maintain battery storage charge and to help run all the electrical accessories, including the ignition and the engine control systems. It is belt-driven by the engine and produces an alternating current (AC), which is converted internally to 12 volts direct current (DC) by the diode bridge or rectifiers.
Car Battery
The battery acts as the nerve centre of a car's entire electrical system, storing energy produced by the alternator or generator and supplying it to those systems requiring smooth, uninterrupted, and continuous current (lights, fuel injection system, main computer). There are several types of batteries used in modern automobiles,
Car Starter
Car Starter is simply a DC motor that turns the engine crankshaft through the flywheel, starting the combustion process by creating compression within the cylinders. Voltage to the starter is supplied directly from the battery and is controlled by a relay and/or solenoid operated from the key switch inside your car.
Thanks
fleet fuel card
Old Dec 15, 2009 | 09:04 AM
Shotgun Love's Avatar
Shotgun Love
there are no actual tips here...
Old Dec 15, 2009 | 09:28 AM
Chopper's Avatar
Chopper
Here's a tip that'll keep your car in good shape.
Look both ways before you cross the train tracks!!!
Old Dec 15, 2009 | 01:13 PM
ChalknCover's Avatar
ChalknCover
Sgt. Killjoy
Yeah, more like a dictionary than tips. and it is spelled tires. Here is my car care tip: 1. Don't romp the **** out of it if you want it to see 150k miles 2. take it in for service every 25 and 50k miles. 3. when something is worn out or broke, replace it. 4. the CEL is there for a reason, if it is on, get it checked out and fixed. kthxbai.
Old Dec 15, 2009 | 02:14 PM
945LSTANG's Avatar
945LSTANG
thanks for stating the obvious in the most general of terms.
Urambo Tauro
Dec 17, 2016 03:30 PM
algregory
Sep 6, 2015 05:52 PM
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
