HELP NEEDED NOW!!!
Old Jan 12, 2010 | 10:11 PM
  #21
southfour's Avatar
southfour
the lever moves up and down fine but the e brake doesnt engage and it wont move foreward to bolt back into the original holes. Is it possible that this problem is in the handle? in the haynes manual it says that you have to insert a drill bit or something into a hole to prevent it moving but i cant find it.
Old Jan 14, 2010 | 03:58 PM
  #22
southfour's Avatar
southfour
ok, i got it fixed. the problem was the e brake lever had wound up and taken all the slack. it workes good now but the calipers rub a bit when the brake is off. Is that normal when the ebrake is serviced. Or how can i fix that. thanks
Old Jan 14, 2010 | 04:11 PM
  #23
Fobra's Avatar
Fobra
Banned
should be some sort of bolt/faster that you can turn to add or remove slack on the end of one of the lines
djbigskrilla
Sep 20, 2022 01:04 AM
yourmom6990
3.7L V6 Technical Discussions
Oct 14, 2015 10:08 PM
MusicCity615
Sep 27, 2015 12:53 AM
J7erry
Aug 29, 2015 10:21 PM
defarmer
Aug 13, 2015 06:40 AM
