Having trouble pinpointing the problem
Old Feb 10, 2010 | 03:41 PM
JoshUsherwood's Avatar
JoshUsherwood
Default Having trouble pinpointing the problem
i have a friend with a 95 mustang 3.8l with a 5 speed. he recently took the car to a shop and put 2000 dollars in to the car to swap the engine with another 3.8 because of a blown head gasket and worn piston rings. the car ran fine for about 4 months with the new engine, but recently started overheating and bubbling and over flowing through the over flow tank. so we then proceeded to replace that radiator cap, and then replaced the thermostat. BUT after replacing the thermostat and gasket, the thermostat housing wont stop leaking. we've gone through 4 gaskets, and we have the thermostat facing the right direction with the spring inside of the lower intake manifold, and we put sealer on the gasket, but still has a constant drip. also, after replacing the thermostat and running the car for a minute, i noticed his radiator was emmitting smoke from the middle part, but i could not see any leaks in the radiator. his coolant is normal color, although this is the same radiator from when the head gasket was blown, but has been flushed. any suggestions? and what can i do to make the thermostat housing to stop dripping?
Old Feb 10, 2010 | 06:14 PM
Chopper's Avatar
Chopper
Check for a cracked thermostat housing.
Old Feb 10, 2010 | 06:15 PM
MustangBradley's Avatar
MustangBradley
Since you have used four gaskets, are you sure that the mating surfaces are completely clean of the old gaskets? If you have even a little of the old gasket still there, you can easily have a leak. The smoke was the spilled coolant evaporating off the fins.
Old Feb 10, 2010 | 10:10 PM
JoshUsherwood
there may have been a little bit of the material from the gasket prior to when we changed it. ill try again with a 5th gasket and make sure the surfaces are spotless. but with the radiator smoke, it is coming from the backside and where coolant could have spilled when it spewed from the over flow container, but we only had the car running for about 5 minutes, and the smoke would become more noticeable as we reved the engine a little bit, and would die down a little as we let it idle for a second. could this still be evaporating coolant? it didnt smell much at all, not enough to determine what it was. it would smoke way before normal operating temperature.
Old Feb 11, 2010 | 08:11 AM
MustangBradley
It will 'smoke' until all of the liquid on the outside of the radiator is evaporated. So, after your first drive to the store it should stop. If not, you have another problem.
Old Feb 11, 2010 | 07:48 PM
Matt's 95 Stang's Avatar
Matt's 95 Stang
Resident Ginger
Also sounds like a crack in the front of the motor right where ther thermo housing is..the odds of you have 4 or 5 defective gaskets in a row...and if you checked the housing for cracks....
Matthew
Old Feb 26, 2010 | 05:41 PM
JoshUsherwood
thanks for the help. we fixed it. there were no cracks. we just didnt put enough of the silicone on it. its been running fine for a while now.
jma2
Jul 10, 2023 01:00 AM
bconboy
Sep 24, 2015 01:55 PM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
ccdguy
Sep 19, 2015 05:20 PM
TorinoCobra070
SVT Forums
Sep 18, 2015 10:34 AM
