fuel pressure problem
Old Oct 19, 2010 | 05:29 PM
00blackstang's Avatar
00blackstang
Default fuel pressure problem
on my small block im running an external magnafuel fuel pump. My problem im having is that the fuel pressure i have sset at 7 every once in a while it will climb and max the gauge out 15 lbs. If i shut the pump on and off mid drive it will go back to 7lbs. the regulators are fairy new and so is the pump. ANy ideas? surge? mayb
Old Oct 20, 2010 | 06:07 AM
petrock's Avatar
petrock
If the fuel regulator is vacuum actuated, you probably have a vacuum leak leading to the fuel regulator. Good luck...
Tivo304
Aug 28, 2023 12:19 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
5.0 kevo
Sep 3, 2015 06:24 PM
cbird1177711
Sep 2, 2015 08:51 PM
SYNY5TER
Sep 2, 2015 01:35 AM
