head swap
Old May 19, 2011 | 03:47 PM
griffen"chancho"ponce's Avatar
Default head swap
hey guys i was wondering if a set of 351 windsor heads will fit on my 93 gt,.
thanks!
Old May 19, 2011 | 05:21 PM
crysalis_01's Avatar
crysalis_01
Banned!
late model 351 heads flow the same as the 302 so if you are upgrading the heads the ones to get are the early style.... But the difference are the bolt size on a 351 windsors are 1/2" and they are 7/16 on 289/302...late model heads have 1.78 intake & 1.46 exhuast valves and early ones have 1.84 & 1.54 & also slightly larger intake and exhaust runners.
Ford began using the same basic head casting for both the 302 and 351W in 1977.
These later 351s, originally identified as 351Ks, have the rectangular 302 intake water passages and 6 intake manifold bolt holes. Original 351W heads have L-shaped water passages and 8 intake manifold bolt holes.
Also, the late model 302/351 heads have a larger water passage at the rear,
which means the intake gaskets are different between early and late models.
If you swap "real" '69-'76 351W heads onto a 302 you need to use the
351W style intake manifold gaskets, as the 302 gaskets will leak water
at the unique 351W intake manifold water ports.
copypasta...but good info none the less.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mustangheaven
Jan 3, 2016 11:20 AM
kevsgt
Oct 9, 2015 10:12 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Drastang
Sep 30, 2015 03:48 AM
