Jacking up your mustang
Old Sep 2, 2005 | 12:39 PM
MikeHawke's Avatar
MikeHawke
Retired MF Moderator
Default RE: Jacking up your mustang
ORIGINAL: 4600cc
On this picture, the lower two arros point to positions. Are those rails solid or hollow? If you jack up there 10 inches, am I gonna mess up anything?
depending on what I am doing to the car, I often put the jackstands on the subframe right there (as close to the front of the car as possible). Never had a problem.
Old Sep 2, 2005 | 01:31 PM
pete1665's Avatar
pete1665
ORIGINAL: Derf00
Add: I dont' agree with supporting the car by the rear axle though.
why not?
Old Sep 2, 2005 | 01:37 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Too unstable, the axle is on a sub chassis that moves. Bump the car or the tires too hard and it could fall. Granted it could fall no mater how it's supported but I don't like the idea of a couple of shocks and a differential control arms holding the rear-end together while I'm under it.
Old Sep 2, 2005 | 04:44 PM
99saleen351r's Avatar
99saleen351r
ORIGINAL: Derf00
If its safe enough to hold together while your driving down the road its plenty safe to be under it thats for sure.Under the axle is one of the safest inmy eyes cause it can slide out from under the frame rails easier than under the axle tubes
Old Sep 2, 2005 | 05:33 PM
Derf00's Avatar
Derf00
Gentleman's Relish
When it comes to safety...I don't second guess myself. I stick to what I know in that area.
Motorcylce - use helmet, gloves and jeans tucked into your boots or pinned somehow
skiing - wear goggles
boating - wear a life preserver
box cutter - cut away from yourself
lifting - use your legs
Working under a car - pick the most Solid/stable points to support the car
That's me.
Old Sep 2, 2005 | 05:57 PM
4600cc's Avatar
4600cc
I ♥ Acer
I have a Titan 3 ton floor jack. Today I stick it under the front K-member from the front, and I could not lift it, there is not enough room to pump the handle. I had to use subframe connectors, but then it was hard to use jackstands.
Jack mentioned is the regular size, same as you'd find in any garage. Does it have to be as hard as I described or am I doing somehting wrong?
Old Sep 2, 2005 | 06:01 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Not familiar with the brand you mentioned but on some of the cheaper floor jacks you have to get a Full pump to get it to lift at all. Many of the mid to high-end ones allow you to get height from any hiegth(sp) of pump. 2 Full pumps and the jack is fully extended.
It may look like a regular run of the mill Garage jack, but they're not all created equal.
NorthAmericanTuning
Nov 9, 2016 11:45 AM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
Jan 6, 2016 07:03 PM
chain
Aug 17, 2015 08:52 AM
daytooday
Aug 11, 2015 09:22 AM
