1988 5.0 pcm
Old Jul 1, 2011 | 06:15 PM
bonesaw's Avatar
bonesaw
Post 1988 5.0 pcm
shorted out my coolant tempature sensor. now the pcm is in an open loop mode could i have burned out my pcm can it be re-set
Old Jul 1, 2011 | 06:53 PM
Soldier GT's Avatar
Soldier GT
welcome.. check out the foxbody section..
Old Jul 2, 2011 | 06:44 AM
Timspony's Avatar
Timspony
SVT Section Moderator
Welcome to MF! ... check in ^^^ at the Fox body area or disconnect the battery...
Old Jul 2, 2011 | 08:53 PM
bonesaw's Avatar
bonesaw
disconnected battery, changed sensor, vehicle loading up won't idle until it reaches temp,then won't run at rpm but will idle.
Old Jul 3, 2011 | 02:29 PM
DJ19895.0's Avatar
DJ19895.0
Are you sure it is the temp sensor? You could be having other issues like map sensor maybe or bad vac line to it.
Old Jul 4, 2011 | 02:54 PM
bonesaw's Avatar
bonesaw
I did find vac lines that were being sucked closed off the bap sensor to the manifold . changed them checked sensors, replaced eec sensor. traced all the other vac lines .
Granatelli Sales
Mar 25, 2016 08:01 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
mungodrums
Sep 28, 2015 10:54 PM
treesloth
Sep 28, 2015 07:03 AM
