Tire Pressure-How Much is Best?
Old Sep 6, 2005 | 11:52 PM
PistolPete's Avatar
PistolPete
Default Tire Pressure-How Much is Best?
I have stock BF Goodrich Tires that came with my '05 V6 Ragtop.
The maximum pressure indicates 45 PSI, but the tires are currently at 32 psi.
Is that too low? I know I will have a harder ride the more pressure I put in.
Should I be at the Max, or closer to 45 psi than I am now?
Old Sep 6, 2005 | 11:59 PM
4600cc's Avatar
4600cc
I ♥ Acer
Default RE: Tire Pressure-How Much is Best?
On my 01 sticker says 30 PSI, that's what I set my tires today. Look for sticker on the glove box door, open the door.
Old Sep 7, 2005 | 01:39 PM
MikeHawke's Avatar
MikeHawke
Retired MF Moderator
yes, you should follow the manufacturer's recommendations. It will be on your door jamb or in your owner's manual.
Old Sep 7, 2005 | 02:50 PM
Birdieman4's Avatar
Birdieman4
I would run them at around 37-38 on the street.
Old Sep 7, 2005 | 02:52 PM
Derf00's Avatar
Derf00
Gentleman's Relish
^^^ I agree. My BFG tires say 44Psi on the sidewall. I run them between 35 and 40. The owners manual is only good for the factory tires and even then can be incorrect because they are typically based on a 35 Max psi tire.
Old Sep 7, 2005 | 06:36 PM
99saleen351r's Avatar
99saleen351r
ORIGINAL: Birdieman4
I agree 32 is low atleast 35
Old Sep 8, 2005 | 12:58 AM
dc_mann8's Avatar
dc_mann8
i run 35
Old Sep 21, 2005 | 11:42 PM
PistolPete's Avatar
PistolPete
Thanks for All the replies...I am going with 35-37...One of my front tires got down to about 30 and taking a corner I heard a squeel a little...
Is it possible to love a car more every mile you drive it?
Old Sep 24, 2005 | 11:57 PM
kartracer55's Avatar
kartracer55
usuallyt you want to run lower profile tires on the high side for pressure, because when you hit a pothole, it decreases your chances of Bending the rim (dont ask how I know) Also, dont over inflate because you will balloon your tires, and dont underinflate, because your will put increased wear on the outside of your tires as well as cause them to get excessivly hot on highways, which could lead to a blowout.
Jim
jwog666
Dec 27, 2021 08:09 PM
CS2007
Jun 25, 2019 09:45 PM
KingRando
Oct 2, 2015 08:06 AM
marc954
Sep 29, 2015 11:18 AM
nmra1965
Other Professional Racing
Sep 26, 2015 10:46 AM
