Fault Code Help Pls
Old Sep 25, 2005 | 12:21 PM
MustangMark_UK's Avatar
MustangMark_UK
Default Fault Code Help Pls
Hey, got a 94 Gt i did a 'check engine light' fault code test and it came up with code 189. Looked up the code and it relates 189 - Adaptive Fuel rich limit reached, left side. Even with Wide Open Throttle the car runs rough, took a spark plug out and is black compared to the right bank.
Am i right in saying that the lambda/ oxygen sensor is faulty?
Thanks for any help, Mark.
Old Sep 25, 2005 | 01:32 PM
vfast's Avatar
vfast
I ♥ Acer
Default RE: Fault Code Help Pls
yes...you have a o2 not relaying the right info.....maybe try plulling it and give it a good cleaning or replace both at the same time
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Dathan
Oct 5, 2015 05:52 AM
mustangheaven
Sep 29, 2015 11:00 AM
