2001 mustang gt problem..someone help thanks
Old Nov 7, 2012 | 11:32 AM
vanhalenfan's Avatar
vanhalenfan
Default 2001 mustang gt problem..someone help thanks
I have a 2001 mustang gt automatic, the other day I leave to go to work and got about a mile down the road I stopped at a stop sign as soon I gave it some acceleration it sputterd and shut off and it wouldn't crank back up so I kept.on trying to crank it and it just spun over then on the last time I tried it spun over a few times and sputterd a little bit and it cranked up. Well i drove it back home and drove something else to work and I didn't mess with my car for 2 days and I cranked it up and it acted fine I drove it to work he last couple of days and I replaced the fuel filter last night and the filter almost looked like muddy water was coming out so I drove it to work this morning and it sputtered when I accelerated bit didn't shut off. Thanks
Tyler
Old Nov 7, 2012 | 03:19 PM
rcunn87's Avatar
rcunn87
It could be bad gas.
Old Nov 7, 2012 | 06:18 PM
Stevo86's Avatar
Stevo86
As he said it could be bad gas, or possibly a bad fuel pump. If you have the means check your fuel pressure at the service to make sure it stays steady. Another easy fix is to check your throttle body. The old 4.6s will get gummed up and run terrible if it gets dirty. A little sea foam or carb cleaner and a tooth brush should do the trick
Stevo86's Avatar
Stevo86
errr service fitting
Old Nov 8, 2012 | 05:58 PM
FrostByte's Avatar
FrostByte
Get rid of that gas & replace it with fresh gas. Then change the filter again.
I wouldn't get gas @ the same place again, EVAH.
Old Nov 9, 2012 | 04:15 PM
2008saleen's Avatar
2008saleen
If it is the original fuel pump there is a good chance it is giving up. Clogged filters make it very hard for the pump to supply the pressure needed to fire the injectors. If it is the pump it will do it again and then eventually quit. Try the gas first. It is the cheapest. I would drain it all into a jug and have a good look at it. Or you could just pull the new filter and poor it backwards into a glass jar. If there is trash in the new filter then you know what is in your tank.
Old Nov 20, 2012 | 01:52 PM
vanhalenfan
i changed the fuel filter and it was terrible!!! so i wend and got some engine and injector clean and filled car up with 93 like always but its still doing it seems like its got worse. could it be the egr valve? Thanks a bunch guys.
Tyler
Old Nov 20, 2012 | 02:35 PM
FrostByte's Avatar
FrostByte
You may have a bunch of crap in your tank & new filter is plugged. Re-check filter.
Old Nov 20, 2012 | 04:34 PM
TomKat's Avatar
TomKat
fuel filter and bad gas would be my guess
Old Nov 25, 2012 | 07:05 PM
craig71springsport's Avatar
craig71springsport
If you replace a filter and don't do a system flush then you need to watch the fresh filter. I think there are fuel additives that you can use to break up sediment and gunk in the tank. Either that or take your tank out and have it cleaned, or get a new one.
NorthAmericanTuning
Nov 9, 2016 11:45 AM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
01moostanggt
Suspension
Aug 13, 2015 07:48 AM
'stangdude
Aug 12, 2015 01:27 PM
daytooday
Aug 11, 2015 09:22 AM
