quad shocks...
Old Jan 3, 2013 | 02:32 AM
blu30val's Avatar
blu30val
Question quad shocks...
I've heard you can remove the factory quads and use control arms in their place, is this true and when im ordering, would I need the upper or lower?
Old Jan 3, 2013 | 11:42 AM
GeigerZ's Avatar
GeigerZ
What's the end goal? Wider wheels and bigger tires? Could keep the quads and just flip them over to allow for more clearance. But, all depends on whatcha gonna do.
I ran my 88LX with no quads for years. Wheel hop with street tires = yes. Running M/T slicks at the track = not likely.
Old Jan 3, 2013 | 03:21 PM
blu30val's Avatar
blu30val
I'm running slightly wider tires.firestone firehawk wide oval,2754517 if I remember correcet. Their not rubbing or anything, it just seems like I'm getting tire hop, and with tcs on the *** end still seems loose. I'm really trying to figure out if its the upper or lower control arms that I'm supposed to use, honestly ill most likely order the b&m combo kit,.but If I find apatial set locally, I'd like to know its not wasted money buying the wrong part.
Old Jan 3, 2013 | 06:05 PM
stevednmc's Avatar
stevednmc
the lowers are what you are most likely after.. The good ones have a heim joint on one end and a bushing on the other.
Read this thread as well. It will help a lot. https://mustangforums.com/forum/susp...ion-guide.html
Old Jan 4, 2013 | 06:15 PM
blu30val's Avatar
blu30val
Thanks for the info. That thread was very helpful
FivePointToTheOh
Mar 9, 2020 10:26 PM
drfister
May 3, 2018 10:38 PM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
Aug 18, 2015 03:39 PM
dangthatsfast
Aug 6, 2015 09:46 PM
