Need help on tranny swap!
Old Dec 16, 2003 | 10:03 PM
USAMuscle's Avatar
USAMuscle
Default Need help on tranny swap!
I was just curious if anybody knows if the Tremec 3650 transmissions used on late 2001 Mustangs and on can be swapped directly into a pre-2001 Mustang that has a Borg-Warner/Tremec T45 without any modifications.
Old Dec 16, 2003 | 11:52 PM
primetime5.0's Avatar
primetime5.0
im sure you'd have to swap out the bellhousing, but dont take my word for it
Old Dec 17, 2003 | 08:26 PM
BLKSTANG9879's Avatar
BLKSTANG9879
If yuor installing it on a 96 or newer 4.6, you shouldn't have a problem.If you go to installed it on 5.0 block then you have to change out the bell housing.</P>
Old Dec 17, 2003 | 11:44 PM
USAMuscle's Avatar
USAMuscle
In case anybody else is curious, I found out from DaSilva Racing in Canada that the Tremec 3650 will bolt up to a pre-2001 GT that originally had a T45 without any modifications, and all that is required to change is the speedo sensor. The 3650 is about 30 mm shorter than a T45, but the driveshaft has plenty of room to allow for that.<edited><editID>USAMuscle</editID><editDate>37972.9061689815</editDate></edited>
Old Dec 17, 2003 | 11:55 PM
SilverGTV8's Avatar
SilverGTV8
Fix the tranny before you but it in. Got to love that second gear grind. Can't wait for Ford to release the TSB for that.</P>
Bokeo
Oct 10, 2015 08:28 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
treesloth
Sep 28, 2015 07:03 AM
2poor4u2
Sep 26, 2015 11:08 AM
