2000 Mustang guages
A bit of an intermittent mess. The tack and speedometer usually work the first few miles but then they both shut down or shut down one at a time.
Gas guage also does the same thing...
Other guages seem to be fine...
thanks
thanks
Seems to be a "loss of ground" problem. Is there a ground that needs to be cleaned behind the radio ?
As before guages work for a while and then stop completely after 5 to 10 miles.
Thanks to all....
2000 guage cluster
Installed a new battery as it was about due, but no changes in the intermittent guage working / not working problem.
Any parts and pieces that can be changed from one instrument cluster to the other that might fix this ??? Speedometer works more often than the tach, but they all seem to stop after about 15 miles....
