First Mustang and first manual ever
Old Aug 18, 2013 | 05:09 AM
dawson1112's Avatar
dawson1112
I am assuming you are referring to one of the top mounting bolts that holds the trans to the engine?
These are usually the most difficult to break loose because of the need for extensions to reach them and still have clearance to turn . Extensions greatly diminish the rotational torque than you can apply and the use of 4 extensions linked together diminishes it by quadruple, it is much better to have a single 2ft extension rather than 4 6 inch extensions linked together .
Sometimes it is much easier to take the hood of the vehicle off and use a breaker with just a socket on it from the top to get it loose.
Optionally you can put some of the other bolts back in and snug them up then lower the tail stock of the trans down as far as you can so you can reach up with an impact driver and loosen it.
Old Aug 19, 2013 | 06:36 PM
gtptim2007's Avatar
gtptim2007
No I was talking about the 4 bolts that hold the transmission to the bell housing
ShaneB26154
35
Mar 4, 2021 04:05 AM
Urambo Tauro
Dec 17, 2016 03:30 PM
1st 4 eyed fox
Aug 14, 2015 09:55 AM
PearlGenPu
Aug 12, 2015 01:57 PM
daytooday
Aug 11, 2015 09:22 AM
