Tail light crack help, need advice
Old Feb 4, 2014 | 12:43 AM
ZStang13's Avatar
ZStang13
Default Tail light crack help, need advice
So I just picked up a '13 mustang and if you haven't heard we had some major cramming going on in the Atlanta area due to snow, Long story short my rear tail light got a small crack in it and now the light housing holds condensation.... permanently.
Does anyone know of a way to seal it without it looking bad? Someone mentioned clear nail polish or 3m clear sealant but others say the only good way is to grind the crack down and do something with JB weld. Grinding my new car is out of the question, I'll use clear tape before I do that...
Also do the tail lights really cost $900 or am I looking in the wrong spot?
Old Feb 6, 2014 | 11:54 PM
ZStang13's Avatar
ZStang13
Dang. No one? No ideas at all?
Old Feb 7, 2014 | 02:03 AM
SPARTAN VI's Avatar
SPARTAN VI
Pics of the crack would help give people an idea of a DIY fix. Otherwise, you can find individual 2013-14 taillights on ebay for about $300-$400 a pop. Then there's always the salvage yard.
Old Feb 7, 2014 | 07:47 AM
PNYXPRESS's Avatar
PNYXPRESS
Is there any damage to to surrounding area to say there was an impact? If not take it to the dealer and try to get it replaced under warranty due to "a defect becomeing apparent from the extreme cold"
Old Feb 7, 2014 | 08:01 AM
AzPete's Avatar
AzPete
First, get the condensation out. Remove the light from the car and use a hair dryer thru the holes for the bulbs to dry it. Make sure you get it all. Then, any clear silicone should reseal the light by you forcing it into the cracked area.
I would not lie to the dealer. If the fix is not right, just buy a new one and feel good about it.
Old Feb 7, 2014 | 10:24 AM
PNYXPRESS's Avatar
PNYXPRESS
Why not? They do it while trying to bend us over.
Old Feb 7, 2014 | 11:05 AM
aaquib1992's Avatar
aaquib1992
How long have you had the crack? Good chance that in that time the condensation has already caused corrosion within the circuit board contacts inside the casing so even if you use JBweld (which might not work forever, and will probably look bad) it might not solve the problem and more issues will crop up in the future.
Personally I also say replace it. Maybe claim it on insurance if your deductible is low enough?
Jb145700
Aug 21, 2022 06:37 AM
bconboy
Sep 21, 2015 12:52 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
Blk Vert
Sep 9, 2015 12:16 PM
amandahchase
Sep 3, 2015 10:09 AM
