turn signal problem
Old Feb 7, 2014 | 03:33 PM
jentastic's Avatar
jentastic
Thanks a lot AZPete!
I'll check on them!
Can you maybe give me a hint where to find the turn signal relay? I think it must be behind the steering wheel somewhere, but I haven't located it, yet.
Old Feb 7, 2014 | 07:26 PM
AzPete's Avatar
AzPete
Did a search and found out there is no relay, it is controlled by the ECU.
If the outer bulb is flashing properly, the one next to it should also since the car does nit have sequential signals, Both bulbs on both sides should receive the signal from one feed from the front.
Old Feb 7, 2014 | 07:49 PM
AzPete's Avatar
AzPete
I just looked at the old harness from my '08. I may have mis spoke above...
There is a red/tan stripe running to the outer two bulbs and these are tied together at the plug. There is a red/white stripe running to the same bulbs but they are not tied together at the plug. Dark blue feeds the inboard light for tail lights, separated from all the above. the harness and plug I reference is the one with the sockets on it at the trunk.
I am not sure which color wire feeds the signals at this time.
Old Feb 7, 2014 | 08:19 PM
AzPete's Avatar
AzPete
Hope this helps...
Brake and signal...
http://iihs.net/fsm/?dir=40&viewfile...rd%20Lamps.pdf
Tail lights...
http://iihs.net/fsm/?dir=40&viewfile...se%20Lamps.pdf
Old Feb 19, 2014 | 01:26 PM
jentastic's Avatar
jentastic
Hey there,
I tried all the above mentioned.
The turn signals in front and back are still constantly burning.
I tried to find a wiring scheme for my ride, but I haven't been successful so far.
Does anybody of you have one I could take a look at?
Thanks!!!
Old Feb 19, 2014 | 01:41 PM
AzPete's Avatar
AzPete
It appears that the flasher as in older cars is now a function of the PCM from what I have read. The 2005 schematics I posted above would help you a lot and if you look on the left side of the page for other the sections you want. I would bet the 05 and 06 schematics are the same....or very close.
musnicki
Sep 23, 2015 07:11 AM
5.0 kevo
Sep 3, 2015 06:24 PM
cbird1177711
Sep 2, 2015 08:51 PM
iculookin
Sep 2, 2015 12:34 PM
