running hot...
Old May 25, 2014 | 10:42 AM
Joe_5.0L's Avatar
Joe_5.0L
Default running hot...
I have a 1990 mustang gt, I've put a new crate engine in (long block) & have less than 50k miles on it. But I've been blowing radiators & heater cores & the upper intake manifold gets extremely hot. My temp gage reads where it should, right in the middle & it does work... the car runs great, just really hot. I don't have oil in my radiator and no water in my oil... anyone have any idea why it could be running so hot? Intake is stock (it is getting so hot that the paint is baking right behind the egr spacer) I need help/things to try I've got a new radiator in, new water pump, I've bypassed the heater core due to the pressure, what could cause this?
Thanks,
Joe
Old May 25, 2014 | 12:25 PM
AzPete's Avatar
AzPete
Do you have cylinder compression leaking into the coolant....that would possibly cause the pressure and heat.
Old May 27, 2014 | 07:53 AM
88 orangepeel notch's Avatar
88 orangepeel notch
First thing to do is get an infrared thermometer, those kind with the laser, and check actual temp of thermostat housing at operating temperature. Foxbody gauges are notorious for being inaccurate. Don't trust the stock gauges. Let us know what is.
Blowing radiators and heater cores really doesn't have much to do with the hot your coolant gets, but the pressure, so check your radiator cap, or just get a new one with the correct pressure rating.
Old May 30, 2014 | 06:12 AM
tw1234's Avatar
tw1234
Rad cap as mentioned above; Thermostat stuck closed or installed upside down? 50/50 Antifreeze mix must be used not just plain water or it will boil at 212 F.
Oct 7, 2015 07:02 PM
heslekrants
Sep 23, 2015 04:02 PM
TorinoCobra070
SVT Forums
Sep 18, 2015 10:34 AM
MusicCity615
Sep 12, 2015 07:05 AM
uedlose
Sep 10, 2015 03:30 PM
