head bolt torquing question
Old May 27, 2014 | 01:39 PM
9550's Avatar
9550
Default head bolt torquing question
hi
according to my manual (haynes, crappy i hear), for a 95gt step 1 is 25-35lb, step 2 is 45-55lb, step 3 is a quarter turn (90degrees)
so, for step 2 i went to 55.
for step 3, i couldnt move a quarter turn. lets say i could go about 20-30 degrees.
im guess this is fine because if i only went to 45lbs during step 2, i could have easily went another 90 degrees during step 3.
any flaws with this thinking?
thanks
Old May 27, 2014 | 01:45 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Are you trying to reuse your old ones or using new ones? Are you using OEM bolts or ARP bolts/studs?
If you're trying to reuse the old ones, that's the problem. They stretch when you turn them 90 degrees. If you try to reuse them they often times won't stretch more or will break during that last step. That's why it's recommend to use new head bolts whenever you do head work.
If you are using ARP brand they have their own specs you should be following, not what the service manual says. Service manual stuff is based on OEM parts.
Old May 27, 2014 | 04:03 PM
9550's Avatar
9550
Ah,I see.thanks. I'm glad I asked.I have arp. Anybody know what the specs are?
Old May 29, 2014 | 02:02 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Sorry, I don't but I see you have a thread open for that specific question so...
https://mustangforums.com/forum/5-0l...arp-bolts.html
Tivo304
Aug 28, 2023 12:19 PM
spamedic
Sep 9, 2015 12:15 AM
cbird1177711
Sep 2, 2015 08:51 PM
cbird1177711
Sep 2, 2015 04:12 PM
