Hot Fox Swap
Old Oct 18, 2005 | 04:31 PM
Velvet Leopard's Avatar
Velvet Leopard
Default RE: Hot Fox Swap
Okee. Unfortunetly, my PonyCat currently is equiped with the single hump crossmember. I may have to just keep that for now though.
Old Oct 18, 2005 | 09:34 PM
tinman's Avatar
tinman
Don't worry about a C-6 trans, C-4 will work fine.
Worry about finding an 8.8" rear instead, you WILL granade the 7.5.
Carb, Go junkin', find hooly vacum secondary 4 barrel of some 70's Ford truck, there are millions of them. Rebuild it.
You will need to get electric pump out of the tank and use 3/8 hard line to the front of the car.
You will also need to do some wiring for the ignition system.......
Old Oct 19, 2005 | 12:55 PM
Tim37's Avatar
Tim37
ok don't freak out about the cross memeber there like 60 bucks new form summit or jegs.
the carb it depends i personaly don't like a rebuilt factory units i like to either get a holly or a edlebrock depending on use a track or weekend car a holly double pumper is the way to go. but for a more every day street car a edlebrock. thats just my oppinion
Old Oct 19, 2005 | 01:09 PM
Velvet Leopard
Does Edelbrock even make a carb for a '71 2-Bbl intake? I am hoping to keep the original intake, but the mechanic I am working with says it may be too far gone to use anymore. I would like to stick with a carbed engine for now. Are there any good aftermarket 2-Bbl intakes for this engine? Thanks for all your help.
Old Oct 19, 2005 | 07:43 PM
Tim37's Avatar
Tim37
forget the 2barrel.
go ahead and buy a 4bbl intake and a good carb. both edlebrock and holly make 2barrel carbs some racing classes dictate that you can only run a 2 barrel so you can buy a fairly large one like 550 cfm but i would consider somthink like a 650 cfm 4 barrel you won't be sorry.
as far as a good two barrel intake just buy the 4 barrel and get an adapter form autoz0ne
bradleyb
Nov 27, 2015 07:50 PM
Bokeo
Oct 10, 2015 08:28 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
