Mystery Box
Old Dec 14, 2014 | 03:41 PM
thomasguzzijr's Avatar
thomasguzzijr
Default Mystery Box
So I did a stupid thing and backed over a curb that I had no idea was there and in the process, the little black box that sits between the two mufflers is hanging from the underside of the car. First, what the heck is it and what does it house? Two, do you think it is easy to fix or should I not chance it and have Ford look at it. It looks like there are screws that were used to attach but obviously these snapped off, but not 100% sure. Any help or guidance would be great. It is a 2014 convertible mustang.
Old Dec 14, 2014 | 05:15 PM
steel pony's Avatar
steel pony
If it's before your axle, it's prob the plastic cover for the gas tank...
If it's any further it's your differential cover, and THAT would be bad!
Kinda hard to tell what it is w/o a pic or 2
Old Dec 14, 2014 | 05:33 PM
JimC's Avatar
Super Moderator
Since he said "black box that sits between the mufflers" it isn't the differential cover or the gas tank.
More than likely it is the emissions electronics box that sits right under the spare tire well. Is everything plugged in still, and are you getting any codes? You probably just pulled it loose from the mounting pegs.
Old Dec 15, 2014 | 04:53 AM
thomasguzzijr
Default Mystery box
Yes it seems everything is still plugged in and I'm not getting a check engine light or codes.
Old Dec 15, 2014 | 05:37 AM
JimC's Avatar
Super Moderator
Then you probably just broke the pins that hold it in place. I don't think it has screws, but I haven't really had any reason to look closely at it either.
Old Dec 15, 2014 | 10:44 PM
cruisin5268d's Avatar
cruisin5268d
Pictures would be a huge help...but it seems like Jim has you on the right track.
Old Dec 19, 2014 | 03:54 PM
tbear853's Avatar
tbear853
https://mustangforums.com/forum/gene...-mufflers.html
Nothing changed .... you are welcome.
jwog666
Dec 27, 2021 08:09 PM
baddog671
Jul 26, 2016 01:20 PM
mapitts
May 15, 2016 02:57 AM
daltron
Apr 28, 2016 08:10 PM
trashxtrash
Sep 20, 2015 10:49 PM
