03 gt starting/stalling issue
Old Feb 23, 2015 | 07:28 PM
03MYWAY's Avatar
03MYWAY
Default 03 gt starting/stalling issue
just bought this car. sometimes fires and stays running, other times fires and stalls right away, but starts and stays running on second or third try. runs and drives fine. only code was cam position sensor, which I replaced, but still has the issue. also had charging system checked and was told voltage regulator in alternator was bad and was over charging. anybody experience the stalling issue with the 4.6?
Old Feb 24, 2015 | 07:02 AM
88 orangepeel notch's Avatar
88 orangepeel notch
Welcome to the forum, sorry I can't help you, but you could start a new thread in the Tech section for your specific year stang. You'll probably get more responses. Good luck
Old Feb 24, 2015 | 08:41 AM
Soldier GT's Avatar
Soldier GT
Post in the 4.6 section of MF. BTW welcome to the forums!
Old Feb 24, 2015 | 05:38 PM
03MYWAY's Avatar
03MYWAY
Thanks
Old Mar 18, 2015 | 12:01 AM
jwog666's Avatar
jwog666
this is common, replace or rebuild the alternator, but beware the el cheapo aftermarket alts. they have a very high failure rate. once the alt is replaced, clear the codes and you should be all set
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Thunderball
15
Nov 22, 2015 11:49 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
Bokeo
Oct 10, 2015 08:28 PM
