Synchro for 5th gear question
Old Jun 24, 2015 | 08:13 AM
meckeard's Avatar
meckeard
Default Synchro for 5th gear question
Hi,
I'm interested in buying a 86 Mustang GT but one thing concerns me. The buyer made this comment about the 5th gear in the transmission:
"Trans need looked at I believe the synchro for 5th gear is bad it will shift into 5th but do nothing"
Should I be concerned with this? I don't mind putting some work in to it but I don't want this to be one of those cases where the tranny is insanely expensive to fix or replace.
Thoughts?
Thanks!
Old Jun 24, 2015 | 01:32 PM
88 orangepeel notch's Avatar
88 orangepeel notch
Yes, if there's no 5th gear, plan on a tranny rebuild. Or find a good used one depending on what your plans are for the car
T5 tranny are fairly cheap rebuild compared to other trannys. Around me there's a guy that does it for $800 with core. And they come with a couple nice updates also. It's odd that 5th went out, usually it's 3rd that goes if any.
And if your doing the replacing yourself, they're very easy to replace. They only weigh 75 lbs if I remember correctly. If your good with a wrench, plan on a couple hours if everything goes well, and your back on the road. Good luck
Old Jun 29, 2015 | 03:38 PM
dawson1112's Avatar
dawson1112
These little t5s are among some of the easiest transmissions to work on, Ive rebuilt several of them. I wouldn't let a little thing like missing 5th gear stop me from getting the car. In fact I would use it as an excuse to low ball the **** out of the guy lol.
Luke9222
Oct 22, 2015 11:55 PM
musnicki
Sep 23, 2015 07:11 AM
Mustangmalo
Sep 6, 2015 05:22 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
