Console Button Functionality
Old Oct 23, 2005 | 03:40 AM
tehnick's Avatar
tehnick
Default Console Button Functionality
I have a 2002 V6, and on the front console near the 12V adapter, there is a set of buttons. One is connected to my rear window defrosters, but 2 are blacked out with faceless plates. I removed the console to get an idea of how I would do it to paint the parts in the near future and noticed that these blanked out plugs do have wires running to them. I am curious as to what these buttons control, and if they are actually wired into the electrical system of the car. Does anyone know what they are for? If I could utilize them without having to drill holes or bitchrig something then that would be sweet. I have big plans for this lil car, and want to start on the interior first and work my way around to the exterior and under the hood.
Thanks!
Old Oct 23, 2005 | 03:44 AM
2000_v6_Pony's Avatar
2000_v6_Pony
Default RE: Console Button Functionality
im alittle cunfosued by ur discription .. is this a stock car? if so it shouldnt have any wires running to the fuse box, everything should be conceled
Old Oct 23, 2005 | 04:57 AM
tehnick's Avatar
tehnick
It is a stock car. There is the defroster button on the bottom left, then there are 2 spaces that have smooth black covers where other buttons would be if my car wasn't the base 2 dr coupe. when I remove the center console above the part that covers the shifter, I can see the plug to the defroster switch, however those 2 faceless button plates have similar plugs with wires coming out of them like they are wired to something in the car but there is no switch present. I will probably have to take pictures of this when I get home to demonstrate what I am talking about.
It's pretty strange...
Old Oct 23, 2005 | 12:23 PM
GreyStang's Avatar
GreyStang
On my '02 GT, the center button turns the traction control on/off, and the right button turns the foglights on/off..
If you don't have factory traction control or foglights I guess that explains the blank button faces.. Got no idea where the wires on yours would be going..
Old Oct 23, 2005 | 02:44 PM
ShadowDrake's Avatar
ShadowDrake
04 GT from left to right...
(Rear defroster) (Traction control on/off) (Fog lights)
In my case, the rear defroster is the blow a fuse button. [:@]
It's possible the wiring is there for them, but you don't have fog lamps anyway, and the traction control is more of an ECU-controlled thing, so making these buttons pressable isn't going to do very much for you. Since the wiring is there, you may want to check a wiring diagram, you will probably be able to use the existing wires, and modify the buttons to control things that you add later.
lincolnshibuya
Jul 5, 2020 03:05 AM
firehorse02
Nov 16, 2015 11:28 AM
lincolnshibuya
Oct 6, 2015 08:45 AM
breaking
Oct 2, 2015 01:27 PM
Sep 30, 2015 12:39 PM
