Trunk pops opens
Old Jun 13, 2018 | 06:27 PM
Stoney's Avatar
Stoney
Default Trunk pops opens
I have a 2015 Mustang V6 Convertible and every time I start the car the trunk pops open. Anyone have any suggestions? A new latch cast $161,84 and I am not sure it needs one, Any help would be greatly appreciated. Thanks
Old Jun 13, 2018 | 07:27 PM
08'MustangDude's Avatar
08'MustangDude
Banned
With the 04-14s, there's a release hatch relay in the engine compartment
fuse-relay center. Yours is Fuse #16, I think... Pull that, see if it happens
again. If not, then you need to nail down the short on start-up.
Also, if you put the key in, then turn RUN without starting, does it pop?
Accy position, does it pop?
Old Jun 13, 2018 | 08:15 PM
Stoney's Avatar
Stoney
Mine does not use a key, just a start button. I will look for the relay. Thanks
Old Jun 14, 2018 | 04:45 AM
08'MustangDude
Banned
Yes, okay, you have to be on the brake for it to start with the button.
So, get in, keep your foot off the brake, and push the button, that will
be the same as "RUN" position. See if the trunk pops open...
I did not see a relay for the 15+, just a fuse designation.
Old Jun 14, 2018 | 09:02 AM
Stoney's Avatar
Stoney
Thank you. Just tried you suggestion and it did pop open when I pushed the button with my foot off the brake. I guess I have a short or maybe a bad relay. Do you have any idea where to start looking? Trying to find a wiring diagram online, not having any luck so far.
Old Jun 14, 2018 | 12:10 PM
08'MustangDude
Banned
Pull fuse#16 first, it should be in your user manual.
After you pull the fuse, see if it pops when you press the button.
This to be sure it's going through the appropriate circuit when it pops...
I do not see a relay designation for it, I do with the 05-14, but not the '15
Old Aug 27, 2024 | 12:06 AM
rafael bomfim's Avatar
rafael bomfim
Default Did you found the issue? I have the same issue
Please advise if you got this issue solved.
Stang Up Comic
Aug 17, 2019 09:48 PM
PcoD
Sep 1, 2018 11:34 PM
getafewlives
May 14, 2008 10:06 PM
BigFloppy
Dec 5, 2005 03:22 PM
whitestanggt
Jul 30, 2005 07:50 PM
