Electric windows do not work -- help
Old Sep 17, 2018 | 04:52 PM
Widall's Avatar
Widall
Default Electric windows do not work -- help
My electric windows on my 2004 Mustang GT convertible suddenly stopped working. They were down but I continued to "fiddle" with the switches and finally got them up but they do not work at all now. I checked the fuses under the dash and under the hood and all check good. I even changed the 20 amp circuit breaker under the dash but no results. There is power at the circuit breaker with the ignition switch on and none when off (as it should be). There is no power at the window switches. If I connect a jumper to the red wire at the window switches all the windows work as they should. What is wrong???? What about merely finding the red wire under the dash, cutting it and connecting it directly to the battery through a regular 20 amp fuse? Would this cause other electrical problems? I purchased the car about 8 years ago and the fog lamps, buzzer when the door is open and the key in the switch, the dome light when the driver door is opened has never worked. I wonder if this is any clue as to why the windows will not roll up and down. Thanks for any suggested that you can provide.
Old Sep 18, 2018 | 06:08 AM
GT Nate's Avatar
GT Nate
isn't there a mega fuse for power windows in the engine bay?
Old Sep 18, 2018 | 06:16 AM
Widall's Avatar
Widall
Yes and it is good. Thanks
Old Sep 18, 2018 | 09:57 AM
GT Nate's Avatar
GT Nate
well... durn.
Possible the electric motors in the windows are just worn out, the brushes all clogged up.. A gentle tap on the motor might free them up, but sure hard to get to them I'm sure...
Old Sep 20, 2018 | 02:07 PM
fastbackford351's Avatar
fastbackford351
Foghorn Leghorn
I have had this happen a couple times on my 02 GT convertible and believe it or not the fix was to hold the button and slap the bejeezus out of the door panel next to where the window motor is. I only had to do it a couple times and haven't had to do that in at least 5 years but it worked. It won't cost you anything to give it a whirl.
Old Sep 21, 2018 | 05:23 AM
Widall's Avatar
Widall
Thanks, but it did not work for me.
Old Oct 23, 2018 | 01:54 PM
MollyMustang7's Avatar
MollyMustang7
My Windows on my 2003 ford mustang coupe will not work. I changed the switch out and I know there is power going in to them because the door locks are working. Please Help, It is driving me crazy.
Young_Gun
Jun 10, 2021 07:44 PM
divercg33
Feb 25, 2013 02:39 PM
cldcld
Jun 6, 2011 10:01 PM
briansharar
Convertible Tech
Aug 10, 2008 03:56 PM
stumpfoot
Oct 24, 2007 07:33 PM
