MAF Injectors Tune Surge?
Old Sep 19, 2018 | 09:25 AM
84conversion50's Avatar
84conversion50
Default MAF Injectors Tune Surge?
Ever since i bought the car the idle quality hasnt been great. 1993 pcm 93 style injection. 427w. The idle surges no matter how high or low i put it. It will idle fine until you dip the idle then it will never find itself and bounce back and forth. It has bright green injectors, im assuming 42lb, and what looks like the original stock maf. Will upgrading the maf to the larger sizes help anything for this issue. If a tune is the only way to fix it is there any places i can send the pcm out and have it flashed. We have 1 guy here but he is booked for months.
Old Sep 19, 2018 | 01:41 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Yes, 42# is bright green. I can't see that current build needing that large of an injector. 42 lb injectors assume 600HP at the crank at a standard 80% duty cycle. 28 or even 32 lb injectors should be max for that motor if you're pushing 400HP
https://www.deatschwerks.com/fuel-ca...tor-calculator
At 42 the PCM is probably having a helluva time trying to control the fuel trim enough value to maintain a steady idle. There's only so much the PCM can dial back or add to the the fuel trim.
Upgrading the MAF may help a but it's still the same story, overrated injectors for the application.
Old Sep 19, 2018 | 03:42 PM
84conversion50
It dynod mid 500s a few years back without the meth kit thats on it now. Is a tune the only solution. If so is there someone that can make a chip based on engine information.
E_LOW
Apr 9, 2009 09:57 AM
WhiteLightning00
Oct 26, 2008 07:10 PM
WhiteLightning00
Sep 16, 2008 09:29 PM
5.0liter_rice_eater
Mar 13, 2008 09:53 PM
KNOXRAGTOP
Apr 21, 2006 06:53 PM
