Carb Conversion Help
Old Nov 22, 2018 | 12:32 PM
kdh023's Avatar
kdh023
Default Carb Conversion Help
I bought a carb conversion kit from jegs and hooked it all up. I’m supposed to hook a loose yellow wire up to the tach wire to work the tach. Can anyone help me find the tach wire please? My car is a 1999 Mustang GT.
Old Nov 22, 2018 | 01:57 PM
08'MustangDude's Avatar
08'MustangDude
Banned
You can use any coil pack signal wire for that.
Old Nov 22, 2018 | 04:56 PM
kdh023's Avatar
kdh023
I went this route because my theft system kept getting thrown, and the people at Jegs said I’d basically throw my ecu away. Now my tach won’t work and my transmission won’t shift.
Old Nov 23, 2018 | 12:18 AM
kdh023's Avatar
kdh023
So if I get rid of my ECU, I won’t be able to use an old coil pack wire, right? If that is the case, where can I one the actual tach wire?
Old Nov 23, 2018 | 09:47 AM
Urambo Tauro's Avatar
Urambo Tauro
I believe the wire is tan w/ yellow stripe. Could be orange/white though.
Old Nov 23, 2018 | 12:10 PM
kdh023's Avatar
kdh023
Thank you, when I get off work I will try that. Is there anyway to address the transmission not shifting?
Old Nov 23, 2018 | 01:43 PM
Urambo Tauro
That's a good question. The transmission is PCM-controlled, so I imagine you'd probably have to get some sort of standalone controller for it. I bet somebody in the Classic Tech section would know.
Old Nov 23, 2018 | 03:27 PM
kdh023's Avatar
kdh023
My theft system got thrown, do you know how to reset it so my transmission will work?
kdh023
Nov 21, 2018 07:59 PM
tohoopty
Sep 24, 2010 05:17 PM
68greenmustang
Nov 4, 2008 08:59 AM
mstngsule68
Sep 25, 2008 04:20 PM
cherryGT
Oct 30, 2004 03:58 PM
