Windshield Wipers Not Working
Old Apr 18, 2020 | 05:03 PM
KonaBlue302's Avatar
KonaBlue302
Default Windshield Wipers Not Working
Dials on my windshield wipers don't work. What could be the issue?
Old Apr 19, 2020 | 09:58 AM
wbrockstar's Avatar
wbrockstar
When you say dials,are you referring to the numerous lines on the multifunction switch/turn signal lever thats used to activate the wipers?? Are the wipers working on the low & high speed settings,but just not working in the other zones which are considered part of the wiper delay system or are the wipers not working at all on any speed?? If they're not working at all,check the various fuses/relay first.There may be both in the underdash & underhood fuse panels.When checking a relay that you suspect is possibly not working, locate another relay in the panel with the same part number (if there is one) & insert it in place of the suspect relay to confirm whether the suspect relay is bad or not.If the low/high speed wipers work,but the delay doesn't,the multifunction switch or the wiper module (for the delay feature) is most likely bad.Im not sure of the modules location on your year model,but I'll research to try and locate it.
Old Apr 21, 2020 | 12:31 PM
fastbackford351's Avatar
fastbackford351
Foghorn Leghorn
What year car is it?
Old Apr 21, 2020 | 12:39 PM
KonaBlue302
2012 boss 302
Old Apr 21, 2020 | 12:42 PM
KonaBlue302
The dials with lines on the side of the steering wheel don't work on any speed setting. It used to work on the highest seeing only for a bit but then it completely stopped working. Checked all the fuses and relays but they're in proper working condition
kjesse198
Feb 18, 2018 11:12 PM
JRad405
Jan 19, 2011 01:18 PM
MontanaMustangGT
Apr 17, 2010 11:59 PM
liljojo4711
Jul 25, 2009 05:40 PM
chriscw81
May 14, 2009 01:06 PM
