96 are staying short shifter issues
Old Jun 17, 2021 | 12:08 AM
Bobby76's Avatar
Bobby76
Default 96 are staying short shifter issues
I just recently change the transmission fluid in my 96 gt 4.6l and I put it back together and now my shifter wants to go to the right I had to force it to the left what can be the problem
Old Jun 17, 2021 | 03:48 PM
365Saleen's Avatar
365Saleen
Define "put it back together".
How does draining and filling the transmission require any dis-assembly?
I assume manual trans because you said the shifter want to go to the right.
Old Jun 17, 2021 | 08:42 PM
Bobby76's Avatar
Bobby76
Default Stiff shifter
When I reinstalled the shifter I put the bushing or plastic cupping back on and everything like I was supposed to and now the shifter just wants to go to the right when its in neutral just go straight to the right I have to force it to the left and into first and second
Old Jun 17, 2021 | 10:01 PM
tbear853's Avatar
tbear853
automatic?
manual?
what did you take apart to change fluid?
Old Jun 18, 2021 | 07:43 AM
Bobby76's Avatar
Bobby76
It’s a manual and I took shifter out to change the fluid I put it back same way I took it out and now it wants to stay to right and hard to go in 1 & 2 I took it back out to double check make sure now grit or dirt anything was in there and still same thing
Old Jun 18, 2021 | 08:18 AM
365Saleen's Avatar
365Saleen
Something changed from before when you removed the shifter. So you are going to have to take a closer look at what you changed. Maybe take pictures if you take it apart again so we can see what it is exactly that you are doing, or have done.
gottagetswole
SVT Forums
Jun 17, 2021 12:30 AM
diverguy64
19
Oct 16, 2007 10:36 AM
RacquetballRyan
Sep 4, 2006 05:05 PM
lucifix
SVT Forums
Mar 13, 2006 01:06 PM
SurfShroom
Mar 29, 2005 11:24 AM
