A4LD not shifting into 4th
Old Sep 29, 2025 | 12:16 PM
MILLSMAN's Avatar
MILLSMAN
Default A4LD not shifting into 4th
'93 Mustang LX with a 4 cyl engine and the A4LD transmission. Transmission will not shift from 3rd to 4th. Shifts fine to all the other gears. I dropped the trans pan, changed the filter and put in new fluid. The trans fluid was clean and no debris present. I checked the 2 solenoids in the trans and they were functioning when I put 12v to them and grounded them. I ran a computer check on the EEC-IV system (with engine not running) and got the following codes: 629566. The 62 code says "Transmission Clutch Fault". Where do I go from here???
MILLSMAN
Aug 24, 2024 01:53 PM
Andy_8591
4 Cylinder NA and Turbo
May 18, 2010 11:25 PM
petespokerplanet
Oct 4, 2008 09:59 AM
manicsmokey
Oct 1, 2007 03:00 PM
whiteout 5.0
Sep 5, 2006 01:09 AM
